Transmission Cooler Line
I’ve got an old '98 Jeep Cherokee with automatic transmission. One of the lines from the transmission to the radiator is leaking where the rubber part connects to the hard line. We figured out how to get the line loose from the transmission, just squeeze the “ears” on the fitting and pull the line out. However, the one at the radiator end is different. It looks like there are 4 spring “fingers” that hold the tube onto the radiator. This is the bottom one and it’s sort of hidden behind the radiator hose. How do I get it off?
Thanks for your help!
