Thank you for your quick response. I recently had the electrial switch replaced, this was not the problem. The mechanic mentioned replacing the valve body could be another possible solution. My other question is, would I be wasting my money if I had this done?
Possibly; any comment like “could be” is a technological guess at your expense.
I would take the car to a good independent transmssion shop (not a chain) and have a proper diagnosis done first. Then you can decide whether it is worth fixing properly.
Thank who for what quick response?
If you want to follow up on something you posted in the past, you need to find your original post and reply to it. This is just a discussion board. There’s no one here who is actually keeping track of your issue and corresponding with you - as if this is a reply to an email.
