So I got the cv axle out of my car and noticed that the new part doesn’t have the splined shaft that goes into the transmission.
The product page for the part says I have to transfer the stub shaft to the new part. I can’t seem to find any videos or advice on how to do this.
What in the world do I do now?
Got it. Sorry to spam.
For anyone googling later trying to find out how to:
Transfer stub shaft
Transfer stub shaft cv axle
Transfer stub shaft cv joint
Remove stub shaft
Remove stub shaft cv axle
Remove stub shaft cv joint
Just wrap a clean towel around the stub shaft on the old axle, clamp it with vice grips, hold the axle up vertically, and tap the tripot of the axle until it falls off and your left holding the stub shaft in your vice grips
I’m also curious about the type of car and the picture along with the stub shaft also makes me wonder about whether you have the wrong part.
I can’t remember, ever, seeing a halfshaft with a removeable stub although most earlier Subarus used stub shafts on the differential with the inner CV joint being splined and pinned with DOJ pins.
There’s also some question about whether you have this car back together and if it actually works.
The car is a 2006 Chevy Malibu. I got the part from Advance, and while I wouldn’t put it past an auto parts store to mess up now and again, the product page indicates this is normal.
Car is back together, and I took it for a 15 minute test drive tonight. It needs an alignment (also replaced a tie rod end), but otherwise it seemed to be riding smoothly and handling fine given the misalignment.
