WITHOUT TRANSAXLE FLUID WITH YOUR CAR START
Yes and no. The car should start, but you’ll probably burn up the transaxle. With the engine running, the transaxle has input shaft and pump being turned by the engine. If the pump or shaft is frozen, then it will prevent the car from starting.
