TPS Help
2007 Suzuki XL7 luxury 6 cyl 3.6l - Error code reads p0122 and the computer in the dash reads Engine Hot- A/C off. It turned over earlier but Car wont start now. Battery is new, all fluid levels, fuses ok. So… can you tell me
  1. a PART NUMBER to search for to replace the TPS? or
  2. better yet provide a SIMPLE STEP BY STEP instruction on how to ADJUST it?
I cant find anything online and I live in a VERY rural area with no mechanics within 100 miles of me.
Thanks!!
@dakotared
On your car the TPS is part of the entire throttle body assembly
Here are the parts
http://www.rockauto.com/catalog/moreinfo.php?pk=1298964&cc=1434295
http://www.rockauto.com/catalog/moreinfo.php?pk=3763623&cc=1434295
AC Delco is $80.79 from rockauto.com
Standard is $158.79 from rockauto.com
If you’re going to replace the part, I recommend AC Delco. The reason I say this is because I believe Suzuki may be (partially) owned by GM. And AC Delco is part of GM
Get the gasket too, while you’re at it. $1.66
http://www.rockauto.com/catalog/moreinfo.php?pk=1042586&cc=1434295
I assume P0122 is a current code, which CANNOT be cleared?
Or if you clear it, it comes right back?
Good luck!
And please post back when it’s fixed!
