My 1982 Toyota Landcruiser (FJ60) was recently hit by a drunk driver while parked in a parking lot. The rear driver’s side door was damaged and no longer opens. I found a 1984 FJ60 in a junkyeard and was wondering if the doors would be compatible for a replacement.
call the nearest Toyota dealership…otherwise just measure the door/hinges/latches…
The salvage yard should be able to cros-reference this for you.
If those two things don’t help, this is a job for a Landcruiser board.
Awesome. Thank you all very much.
