To use sealant or not? Water pump installation
I usually use the permatex high tack on the waterpump side to hold the gasket in place and use Permatex® Water Pump & Thermostat RTV Silicone Gasket Maker on the side of the engine. but you can just use the RTV silicone or the right stuff by itself like Tester said.
