How on earth does the tire pressure indicator on the dashboard know the tires are low?
Either by the ABS system monitoring a sudden change in the rolling circumference of one tire compared to the others, or by a actual pressure sensors in the wheel.
Are you guessing one or the other or are both methods used?
Both methods are used depending on the make model and year.
