So put a Patch on the Hole that was created by a huge Nail. Already put in Air into Tire. Dash board says “Tire Pressure Low”. I know it’s saying this bc this new high tech monitor car now depends on it. It prob says this bc it was off balance for a while. How do you make this sigh go away?____. Facts. Honda accord 2018. 11,000 miles. TIA
Edit: 2018 not 2019
Step 1: car is still under warranty. Drive to dealer. Tell service advisor what you told us. Let them correct it.
It’s also possible that the patch failed and your tire pressure is, in fact, low.
Solution is most likely in your owners manual.
If the warning light does not turn off after a period of driving you will need to perform the calibration procedure on page 497 of the owners manual.
Do you have a tire pressure gauge? If so, check your tire pressure. If not, buy one for about 10 bucks and check it yourself. I like the Accu-Gage dial unit. I’ve seen them at several autoparts stores.
Nooooooo…not the owners manual…Arrrggghhhhhh!!!
