Tire date code
Had a tire replaced due to road damage. We had road hazard warranty. New tire is dated 3520. Or 2 years old. Dealer had 1 tire in stock that brand/model and size. Oddball. 65 series. 2 yr old is fine?
It should not be a problem at all.
Was the tire stored inside the shop/warehouse, temperature controlled environment, & out of direct sunlight?
Do you have any other tires that are nearly 2 years old? Every tire I own is more than 2 years old.
Well, I’d prefer a 2022 new tire
I’d prefer a 2010 tire that was built with traditional additives to inhibit dry rot like we had in the 90s.
Not a chance in hell I’d buy a tire 12 years old. Unless it was an emergency situation and was the only option.
The tire industry thinks that anything newer than 6 years old is suitable for sale as a ā€œNewā€ tire. I somewhat disagree.
The company I worked for tested 3 year old tires and couldn’t find a difference - and that’s what I go with.
More dangerous nonsense from the Snowman .
Shop wanted $15 for new warranty. Said I had used the warranty on old tire and I needed a new warranty. For new tire. Dang extended warranty’s.
What else would you expect from the SNOWMAN.
If I was going to drive enough that the tire would be worn out in 2 to 3 years, I would take it.
I recently put new tires on a vehicle that doesn’t get much use. I told the tire shop that the tires need to be less than 1 year old, or I would not accept. I told the tire shop if its older than 1 year ā€œget it out of here!ā€ This is because I am not paying new price for an aged tire that I will have to replace sooner because I was sold old stock.
Tyres have use-by dates as the compounds harden and affect braking and handling. That someone doesn’t notice the difference with old tyres is a fault with their perception or they do not put themselves in ā€˜at risk situations’. I choose tyres which give maximum performance way ahead of longevity. I also mention that cars which have been suspension modified put tyres to the test. Buy current year and preferably within a month or two of the construction date on the tyres and toss them after 3 years…no matter how much or how little tread is legally remaining. Same story on indemnification as all mod’s and bad service…as an assessor if your tyres are ā€˜out of date’ I could refuse your insurance an more readily if the tyres are significantly involved in the damage.
I doubt if that is common practice even where ever you live . Our resident tire expert does not say to toss tires after 3 years . I have no idea what this assessor position is .
Like a gallon of milk? Where is this date? On the sidewall somewhere? All I’ve ever seen was the production date. Sorry but I just can’t see throwing away perfectly good money/tires every 3 years. But more power to you if you can.
I think you would be laughed out of court (because you’ll likely end up there) if your denial of coverage was based on a 3 year ā€œexpiration dateā€ with a still legal amount of tread left.
P.S. any relation to a couple others here?
Nonsense, really.
Fake news! Michelin says after 5 years from date of manufacture that you shall have tires inspected once a year. After 10 year you should replace them regardless of tread depth or appearance.
Are there actually any mainstream tire manufacturers that say you should discard tires at 3 years old? If so please provide a link with the information.
GoldMort is obviously not in the US. Things may be different where he is. Especially the part about being an assessor - which I think he means an insurance adjuster. I have never seen an insurance adjuster deny a claim because the tires were too old. Not saying it hasn’t happened. Just that it is rare.
True, but I can’t imagine anyone, anywhere, saying 3 year old tires should be discarded just because of age. That would be both unnecessary and wasteful.
I’m guessing Europe. I just checked the tires on 2 Toyota’s, 1 Dodge, and 1 BMW. NONE have a ā€œuse by dateā€ anywhere on them.
