i replaced head gaskets in 98 caddy 32 valve northstar engine. i marked both cams before removing chain then put cams back in exact same place. put chain on now engine valves rattle on left side. i pulled front covers off and both valve covers then lined up timing marks on crank with all 4 cams timing marks at 90 degrees and still same rattle like engine is not timed. what am i doing wrong?
Related topics
| Timing chain replacement went wrong | 14 | 17395 | June 22, 2020 | |
| 1980's KZ550 Kawasaki Motorcycle Timing | 26 | 7080 | April 30, 2016 | |
| I'm a dummy and rotated the Cam shaft independent of the Crank shaft | 6 | 55796 | March 2, 2014 | |
| 2.4 2013 buick timing issue | 27 | 6135 | August 5, 2023 | |
| Stuck trying to Change Timing Belt | 66 | 12236 | October 4, 2022 |
