Do people do Tie Rod End alignment as often as wheel alignment? Is there any symptoms when I need to have it align?
The tie rods are used to adjust the toe on a car and this is part of every wheel alignment.
There may be symptoms or there may not be. A good rule of thumb is to have the car aligned about every 40-50k miles and check suspension components at that time.
I see thank you.
