Interesting car tidbit: The inventor the diesel engine was originally inspired by a simple fire starting gadget such as this one.
This seems to imply a diesel engine could work using a simple carburetor method, rather than direct fuel injection. Have there been any carbureted diesel car engines?
Diesels are not carbureted. They don’t need a narrow air fuel ratio to run properly. They almost always run lean - excess air - so they have no throttle plate. The speed znd load varjes by adding more or less fuel. Ignition happens when the temperature of compression rises high enough to ignite the mix and the timing is done by when the fuel is injected.
A blown oil seal in a turbo acts as a carburetor. The engine starts running off of its own oil.
I think this method doesn’t work well because the ignition can take place too soon, so that ignition is happening while the piston is still going up. This reduces engine power!
Simple physics dictates the ignition would occur near the top of the compression stroke, which is approximately the correct time. But you are right that this may not be the exact time in the cycle for an automobile engine to yield the best power/mpg/emissions possible.
That glow-plug engine isn’t what I’d call a diesel, I don’t think it would work without the glow plug, while a warmed-up diesel doesn’t need one. Glow plug (model engine) - Wikipedia
The small model-plane engines I used to enjoy as a kid required a special fuel. It smelled like gasoline w/some sort of additive, no a diesel odor. I think it might have been nitro-methane. They wouldn’t start if glow plug failed, but they never stopped working once I got them started unless the plane ran out of gas or it crashed, the latter being the more common way the flight ended … lol …
An automotive diesel engine doesn’t “need” a glow plug to start, even when cold. It is an aid, and greatly helps in start up emissions. This could be argued in certain climates, but as long as the batteries are strong enough, the engine will build the heat to start.
Yeah, agreed. But I’d expect that they still need some control over ignition timing. At altitude, thin air would ignite later than sea level air, you’d also presumably want some different ignition at different engine speeds.
A carbureted diesel would allow none of this and I presume that’s the reason they don’t exist in the mainstream.
Years ago I suggested carburatediesel would be.tter than fuel injection because more fuel would be surrounded by O2 molecules.
Same with gasolinengines today.
Plus how much energy is expended compressing the fuel to inject against high cylinder pressures?
Nope. The ignition in a glow plug engine comes from the continuously hot glow plug wire, which also is made from platinum, adding catalytic effects enhancing ignition. The Wikipedia article explains this:
" The glow plugs used in model engines are significantly different from those used in full-size diesel engines. In full-size engines, the glow plug is used only for starting. In model engines, the glow plug is an integral part of the ignition system because of the catalytic effect of the platinum wire. The glow plug is a durable, mostly platinum, helical wire filament recessed into the plug’s tip. When an electric current runs through the plug, or when exposed to the heat of the combustion chamber, the filament glows, enabling it to help ignite the special fuel used by these engines. Power can be applied using a special connector attaching to the outside of the engine, and may use a rechargeable battery or DC power source."
Diesel engines depend only on compression heat for ignition.
Also, the compression ratio in glow plug engines (7.5:1-9:1) isn’t high enough to initiate combustion without the hot glow plug.
That is the most important statement about diesel technology.
Gasoline diesels have been and are being tested. With direct injection technology, the cold engine can be started with a spark and once warmed, continue as a compression injection engine making it a gasoline diesel. The very high compression ratios make the engines more fuel efficient. The direct fuel injection is the “timing” for the combustion.
