Temp gauge not working stays at C doesn’t move at all. And smelling anti freeze while driving. The heat still works and not wet on carpet of passenger side. Does have an oil leak I think since I’ve had to add more oil again. Would that have anything to do with an antifreeze smell tho? Just checking before I have it looked at it. Also the gas gauge just floats that hasn’t worked in a while tho. Thanx
T
T
Thanks again
Car Make, Model, & Model-Year?
CSA
First question from me is do you know how to check your oil and antifreeze levels? If you do, are you loosing antifreeze and how much oil are your loosing. I.e., how many miles/days between having to add oil and antifreeze?
