Clutch is not disengaging on 96 Toy. Tacoma
. Have replaced slave cylinder and bled. When clutch pedal is depressed it does not come back up, in fact it is “sucked” all the way down to the floor and must be pulled back up. Is the master cylinder bad?
Could be.
Take a look up under the dash where the clutch pedal rod passes through the firewall, and see if hydraulic fluid is running down the inside of the firewall from the master cylinder.
Thanks! Will check it out!
