Synthetic or not to Synthetic
I have had a remanufactured motor installed in my 2004 Tahoe. (Kept my old motor for project). Anyway the shop gave me a directions sheet and it states to change oil at 500 miles but NOT to use synthetic oil. Then go 3000 miles and then I can use synthetic if I prefer.
I have not called the shop yet but curious if anyone understands the reason for this guidance ?
That is what the shop says to do . They are the ones who will handle what warranty problems you might have . What more reason do you need ? And yes you should let the shop explain it for you.
There are very good mechanics that post here but if I gave you conflicting advice how would you even know if I knew what I was talking about.
Edit - don’t know what the warranty is on this engine but if the shop does oil and filter changes I would have them do the changes during the warranty period .
Synthetic oils lubricate more efficiently. He wants you to use regular oil to help the rings seal to the cylinder walls. It is a break in procedure.
That is the reason right there…
Thanks tcmichnorth and mustangman for the info. This is exactly what I was curious about.
Volvo-V70 really? Cmon really? If you don’t know just pass. I don’t need to hear something I already know. “cause that is what the shop said to do” ?
Auto manufacturers must do a different process because new vehicles will be delivered with synthetic oil…normal oil that vehicle is suppose to use as outlined in owners manual. I haven’t seen a new engine with break-in oil for any special oil for the break-in period for decades.
With later model cars the machining tolerances have greatly improved making a wear in break in unnecessary.
This 2004 Tahoe should fall well in what’s considered a late model. All I can assume is the builder can’t build to the same tolerances the manufacturer can.
I think this is the correct reason. There may be a bit of… “This what we have always recommended” as well.
This makes sense…or the manufacturer is somehow doing a break-in before they are shipped. I’m sure a good builder knows what they’re doing…I’m just curious why.
I think most/all rebuilders are using very different equipment to grind, hone, and set clearances than the manufacturers, so I’m not surprised that the break in instructions are different.
