I have a Mazda 2002 MPV.  I posted a question a week or so ago about technical service bulletins as there is one for this problem.
 My sway bar link, which seems to be part of the front suspension, is making a popping noise when driving over bumps.
 I have no idea what a sway bar link is or what purpose it serves, but it has been worked on several times while it was under warranty.
 My question is this - Does anyone know if this is dangerous to be driving with it making these popping noises?  I won’t be able to get it into the garage for a week or so.
 Thanks in advance!
No One Is Answering
The sway bar keeps the car from leaning too much in a turn, reduces “body roll.” I think you are going to have trouble finding somebody to say your’s isn’t dangerous like this or they wouldn’t have put it on your car to begin with. I would think the  problem would be if it advances from “popping” to “letting go” suddenly or the link breaking. The car’s handling could change and I would wonder if a dangling bar would damage or interfere with a tire or brakes or steering.
You should make sure that your anti sway bars work. It would help if we knew what the TSB says. If this is a continuing problem, an aftermarket end link may work better. I would check on an MPV board.
That’s a great idea. Thanks for the suggestion!
