The car: Suzuki Esteem 2000, Automatic, 1.6L engine (G16).
So far I did tested and it is OK:
fuel pressure,
Compression is about 120 psi
Timing belt, correct settings
No codes from on board computer
Spark exist on all 4 cylinders, but for some reason it looks like is 180 degree off.
Starter is cranking.
NO START!
Any suggestions?
Regards
Marek
180 degrees off, sounds like timing belt or chain to me.
How are you comming to the conclusion the spark is 180 off? Something like valve position says #1 should be sparking but spark is at #4?
Timing Belt is OK.
I did checked so many times. I can post pictures.
I did put white mark on crankshaft timing pulley.
Connected timing light to the first spark plug wire and …
Light get ON, on oposite side then are timing marks on timing cover.
I did get the car as is with out knowing the history.
It looks like somebody put wrong cylinder head or … I do not know.
HELP!
