Hi All, I have a 2009 Subaru Outback with 60K miles and this problem has been present since I purchased with 30K miles. When turning left or right over uneven surfaces (like washboard dirt road, potholes, or strips of Botts’ dots in a parking garage) there is a loud, audible rattle coming from the front end. It sounds like to metal pipes hitting together. The noise does not happen when driving straight.
Subaru and another garage have inspected. Front struts and sway bar links have been replaced with no effect. CV joints, ball joints have all been inspected with no issues found.
I read on a forum that it may have something to do with the power steering fluid, that when turning there is uneven pressure on both sides and it results in the noise. Possible at the steering column universal joint.
Has anyone experienced this and found a solution? I assume since it only happens to some Subarus that replacing the correct parts will resolve the issue.
Thank you!
