Subaru oil consumption 98k
2013 outback, 98k miles. Down whole quart, 5700 miles since last service. Thoughts?
That sounds normal for the number of miles on the vehicle.
Did you know that some vehicle manufacturers consider a quart of oil consumption per 1,000 miles is normal on their brand new vehicles?
Just check the oil level on a regular basis, and add when required.
+1 to Tester’s comments.
My 2011 Outback currently has over 83k miles on the odometer, and while it rarely needs oil between oil changes, I still check the oil level every few weeks. If I find that the level has fallen by 1/2 qt., I immediately replenish it with the correct specification oil.
Rather than waiting for an extended period of time, and finding that that your oil level has dropped by a full qt, I would suggest that you check the oil level much more often. What if the rate of oil consumption increased, and you found–after an extended period of time–that the level was 1.5 or 2 qts below the full level?
Check your oil at least every couple of weeks in order to prevent problems, and–of course–be sure that you don’t go beyond the mfr’s specified intervals for oil changes. Bear in mind that those intervals are expressed in terms of odometer mileage OR elapsed time, with a “whichever comes first” proviso.
:thinking:
That doesn’t seem unreasonable for a car with that many miles. Did this issue just start now?
Yes. Check your oil a lot more often than every 5700 miles.
Which is it?
More often?
Or every 5700 miles?
Edited for clarity :wink:
Not bad at all, many consume more and it also is affected by type of service. Check often, you never know when a seal or gasket might fail and suddenly you’re down 2 qts.
Check for leaks: oil switches, cam seals, and valve cover gaskets. The only difficult seal to check is the flywheel seal. Also, check the exhaust pipe. If the tip is black it’s a pretty good sign that you have an oil consumption issue (rings, valves, etc.). This is obvious but if you’re blowing black smoke then you are “burning” oil. If you can pull the plugs check them. There shouldn’t be any black on them. They should look tannish. It isn’t normal for motors to use a discernible amount of oil (except for those in old British cars which burned a quart every thousand miles right off the lot.), If the oil consumption started right after the service, the only (pretty far fetched) reason might be a change to a lower viscosity oil.
Every Subaru I used to own (5 in total) was burning between 0.5 to 1.5 quarts of oil per 5000 miles oil change interval I observed.
It is not normal for the car to burn oil… unless it is Subaru :slight_smile:
Not a problem in general, but requires owner to pay attention to that requirement in user manual to check oil level regularly.
If you’re going 5700 miles without checking the oil then you’re lucky to still have a running engine.
If the engine is not leaking then it’s burning the oil. Running extended distances between change with the oil level low can contribute to an oil consumption problem. Especially if you live in a dusty or high humidity area.
That’s the oil usage rate I’d expect w/ a new engine. Besides remembering to check the dipstick more frequently, no worries.
they’re not alone
I know of at least one manufacturer . . . I’m not thinking of Subaru, by the way . . . that considers engine oil consumption of 1 quart per 600 miles to be acceptable. Could be they’ve changed their tune now, but that was their line just a few years ago
Read the article:
https://www.consumerreports.org/cro/magazine/2015/06/excessive-oil-consumption/index.htm
Does that manufacture happen to have 2-character name? letters happen to sit nicely one atop another in a circle? :slight_smile:
Using 1 quart over 5700 miles, is not considered anywhere near excessive.
No, actually, it is the high-priced version of a VW, namely Audi.
A few years ago, we had several posts from aggrieved owners of new or nearly-new Audis who were concerned about the very high rate of oil consumption of their vehicles. In each case, when they kicked their concerns up to the corporate level, they were told that “Audi considers the consumption of 1 qt every 600 miles to be within normal limits”.
:thinking:
Subaru claimed that 1 quart per 800-1000 miles was normal and settled a class action suit over it.
from the link @johnznot shared, it looks like Audi is now surpassed by BMW in this “hall of fame” roster
so, apparently Subie is not that bad
A quart every 5700 miles on an engine with 98K is excellent.
Contrary to the claims of some, all engines burn at least a minute amount of oil. When the oil rings wipe the cylinders down, a small amount is left captured in the intentionally created cross scratches called “honing” in the cylinder walls for the compression rings to slide on. Without this captured film, the rings would tear the cylinders apart. That film of oil ends up getting burned in the combustion process. As the engine gets older and wears, the rings lose their springiness, the cylinders grow from wear (in a conical fashion), and oil usage grows slowly.
You have a perfectly healthy engine. Monitor your fluids regularly, keep up the maintenance, and this one should serve you well for many more miles.
