Steering noise
2000 subar outbck. makes rubbing noise while turning left. does not make noise while turning at a stand-still. does not make noise when in a turn @ holding steering wheel steady. pwr steering fluid is ok & no noise coming from steering pump. any ideas ???
Your tire is rubbing on something as you turn, you do not hear it and a stand still because your tires are not turning. Most likely you have a loose wheel well liner rubbing on the tire. Check both tires.
both tires are good. both wheel wells are stable & secure. once again, the noise(not metal or clicking) does not occur even while in a turn while holding the wheel in position. only while the wheel is being turned.
It sounds like a problem in your steering/pilot valve.
is a steering/pilot valve something thats easy to check ???
Cancel.
