cold starts great. after driving for awhile and you shut it off, sluggish restart at times have to crank for a minute. replaced both 02 sensors and catalytic converter. ck engine lite states running lean no apparant vacuum leaks help me please
please check the temperature that is been reported to the PCM.
thanks will check cooling temp sensor appreciate you lots
