how to remove the starter on a 95 ford explorer after the bolts are out
If it wont come out and you have removed bolts, tap on the side of starter with a mallett.
The starter is loose but dont have enough room to drop it out between engine block, front transaxle, and frame.
sounds like you’ll need to unbolt the mount on that side and jack up the engine a bit. Be careful you don’t break the oil pan.
