Starter motor issues in old Ford
Quite often, when I start my 1982 Ford Granada, it doesn’t crank, but makes a scraping or grinding noise. I have to release the key and try it again until it cranks. I would like to know if the problem could be caused by something else besides the starter motor, such as a solenoid or worn gear.
Yes …
Have the starter removed and check if the ring gear looks like this.
Unlikely. The noise you hear is the overrunning clutch in the starter drive slipping. Replace the starter.
Can’t speak to OP’s car, but the final drive mechanism is a relatively inexpensive replacement part for my 50 year old ford truck’s starter. 302 engine. I’ve never had to replace it, truck still has original starter motor. Tip: Good idea to keep your Ford’s battery fully charged, cranking attempts with a weak battery is hard on starters.
