I HAVE REPLACED THE STARTER 4 TIMES ON MY CHEVY CAVILER AND EVEN WITH A NEW STARTER WHEN YOU START THE CAR IT GIVES A HIGH PITCHED WHINE AND THE STARTER KEEPS RUNNING AND I HAVE TO SLAM THE HOOD TO GET IT TO TURN OFF BUT IT EVENTUALLY BURNS OUT IN A WEEK. THE SHIM IS INSTALLED THERE IS A NEW ALTERNATOR I CANT GET BACK AND FORTH TO WORK CONSISTENTLY AND THIS ISSUE IS GOING TO COST ME MY HOME AS A RESULT IS THERE ANYONE OUT THERE WHOM CAN HELP.
I Believe That The Clearance Between The Starter Gear And Flywheel/Ring Gear Has To Meet Specs.
The clearance has to be checked by feeler gauge and shimmed to the proper clearance. I believe this is more of an issue going to an aftermarket starter than staying with an OEM part. You might need more shims or a thicker one.
If the teeth got screwed up on either gear from this condition, problems could have been created. Check the teeth for smoothness.
CSA
Search The Web For Procedures.
Here’s a link to click for one site.
http://www.bulitpruf.com/bulitpruf_super_clutch.htm
CSA
“THE STARTER KEEPS RUNNING”
Bad ignition switch.
