What can cause a car to stall?
Vacuum leak; dirty injectors; water in the gas; low idle setting; very dirty (clogged)air filter; clogged gas filter; bad connection to the ignition; etc.
If you have a specific problem, give specific details. The problem of STALLING is too broad without providing details to make the diagnosis small enough to handle.
