*1996 Honda accord LX. 255, 498 miles.
Well, a couple months ago I think I overdid it on the seafoam spray in my PCV valve. It was kind of hell to start, I put some starter fluid in there and it finally cranked right over. I thought that was the end of it, but now I’m thinking it was a coincidence.
Today I went to start my car and it wouldn’t rev up to about 200 max out and then drop. If I stopped cranking it with the key, it would die. Well I put starter fluid in the car and it still wouldn’t go! I had to crank it for about 12 seconds to get it to turn over, normally when the engine catches(My foots full on the throttle when it won’t start) it soars to 2.5k RPMs pretty quick. I started it later at school and it acted like it wanted to give me trouble, but a second past and it turned over and started running. I pull into the driveway today and I see my oil light flickering a little bit. First time I’ve ever seen it, a little worried! I turn the back on, starts up right away, to see if the oil light comes back on and nothing. But still worried.
I also got a coolant leak somewhere that I haven’t been to diligent about finding. I don’t see coolant anywhere on the driveway, my cars drinking coolant and I don’t know where it’s going. I checked it the other day and the reservoir tank was bone dry and so was the top of the radiator. I just added some UV dye to see where it’s going, UV flashlight is on the way.
Also, my oil level is fine. So confused, I’m not sure what’s wrong or where to look.
