What do you think the problem could be?
Low on oil. Engine damage causing smoke. Keep this up and the engine will seize, it will stop smoking then
How low was the oil?
Yup!
That is the key question, along with…
How long has it been since the OP last changed his oil, how often does he check his oil between oil changes, and how much oil does it typically consume between oil changes?
