hi, i have a question about my 95 maxima…
the check engine light came on and i checked it and the code P0325 came out…which says its my knock sensor no. 1 circuit malfunction…
first what does that mean? 2nd, should i just change the sensor or is there a reason it came on? i do remember tuning it up last spring…
thanks
You posted this question a few days earlier and got some interesting replies.
Check your original post over here:
http://community.cartalk.com/posts/list/487009.page
And if you decide to change the sensor, let us know if you have been able to find it…
sorry for the repost…
i turned away from the pc that day and it disappeared…and the wife said it didnt post…
thanks again
When someone replies to your post, or you make additional comments to it, the post moves to the front of ALL the posts, and then moves back as newer posts are added. You, then, have to click on First and then keep clicking Next, until you find your post. I have requested a time and date stamp on original posts. An ID number would help, also. I expect to see results of my requests in a few years.
