I scan my Obd system , it gave that a,b,c solenoids are stuck off whats the problem
The power for the transmission solenoids comes through a “Constant Control Relay Module”. I suspect there is a fuse that supplies that relay. So see if there is B+ voltage on the wires going to the solenoids at the plug going into the transmission.
Hope this helps. Let us know what you find.
