The interior door handle’s chrome on our 2002 Camry has cracked leaving a sharp edge. Several layers of scotch tape helped, but the wife is still not happy. I thought about heat shrink and of course replacement. Any suggestions?
Can you file the sharp edge down?
http://www.1aauto.com/1A/DoorHandleInterior/Toyota/Camry/1ADHI00111/264235
http://www.1aauto.com/1A/DoorHandleInterior/Toyota/Camry/1ADHI00112/264236
Google is your friend…
I tried that but the thin layer of chrome just keeps chipping and stays sharp.
Until you replace it, try clear nail polish after sanding.
Heat shrink would work if you remove the handle first ( I can just see you burning the door trim panel with the lighter you’d use to shrink it with. )
Try a fine sand paper instead of a file.
I’d replace it rather than mess around with half fixes.
Or you could just take a knife and remove ALL the chrome.
Metal tape?
Replace the handle, everything else is just an unsightly patch.
