I have considered that.
I do not believe I ever stated that I was considering modifying it.
Thanks. Great advice.
There are always be those who just like to complain or act as know it alls.
If someone asks what I think or I decide to help, I will only do so if I can do it cheerfully.
I may try that.
OR more graphite.
Just kidding. ![]()
Some people would probably consider adding an unapproved type of lubricant a type of modification. At least your shirts are still clean ![]()
I think a lot of the commentary and confusion stems from reading that someone put something (anything) on the fabric portion of a seat belt to correct a problem of the belt not retracting. Applying something to the belt couldnât possibly help to correct this problem, and I think some of the replies you received were from people who were surprised that you tried that.
In answer I say they you may want to look up graphite and see what it is used for.
It is used for lubricated locks and many other uses.
Graphite reduces friction. And reducing friction of the belt will aid in itâs retraction.
Maybe they were surprised cuz they did not think of the idea.
Graphite may indeed be used to reduce friction . . .
But that doesnât change the fact youâre not supposed to apply it to the seat belt webbing
I believe âtheyâ were surprised you did that, because they knew itâs a no-no
And they hadnât considering doing it themselves, because they knew it was the wrong thing to do
To sum it up, I agree completely with @asemaster
WHAT??? I think some of your responses were so incredulous because of that idea. Thatâs akin to saying âI have a tire that does not roll freely on the pavement so I lubricated the tireâ instead of addressing the root cause wheel bearing or brake issue. The issue with your seat belt has to do with the retractor/locking mechanism, not the belt itself.
And maybe moreâ if they are a good at diagnostics, saving you a lot of time and money in long run. If they are pleasant and informative also, that earns them points (and bucksâŠ)
My post about the seat belt has been beat into the ground.
Itâs time to move on.
The part that needs to be cleaned and lubed is the spring and spool on
the retractor. Usually you need to remove some trim to get to them.
Be VERY careful if you have a newer (2005 and up) car. Most have sensors
for the air bags as well as locking charges that fire with the air-bags.
â
Steve W.
Whereâd you pick that 2005 date?
Airbags, crash sensors and etrs have been around a longer than that . . .
I was just posting some advice I got.
Next time try to verify before repeating. Are you Andrew or Steve as if it matters?
