Okay guys, I’ve done everything imaginable to stop my adorable Saturn Sky from overheating. I’ve replaced the water pump (it needed it), I’ve replaced the entire fan assembly (ultimately not sure it needed that), had top end cleaned, then rebuilt.
The fan is not coming on when the engine gets hot. BUT, if I pull over and pull out then push back in the fuse for the fan - VOILE! the darn fan kicks in. It may work again for a few days, or it may stop again 5 miles down the road. But I can always get it running again with my little fuse “reboot.” When I go to pull the fuse, if the engine is hot, I hear a clicking like a relay trying to open and close. But, there’s not a fan relay on my model.
I’m almost at the point of just installing a toggle switch to manually turn on the cooling fan. Any ideas at all???
