my car is non turbo it idles rough, I changed the plugs had the timing belt and all other belts were replaced. before i go and replace the wires is there something that I am missing. had
Has anyone checked the motor mounts?
Thank you, my brother said the same thing I will do that this weekend, but would that affect the RPMs as well?
It could, depending upon just how bad a condition the mounts are in.
Thank very much, could it be possible that the mounts would go with only 86,000 miles on it?
Absolutely. I had to replace the “dogbone” front motor mount on a Chevy with only about 60k on the odometer.
And, if the engine ever had a serious oil leak, that makes it even more likely for the rubber in the motor mounts to have deteriorated by 86k. Is there a lot of oil on the engine and other areas under the hood?
