I have 2001 Chevy Venture minivan on wide right turns on the highway i am getting a vibration from the right rear of the van. the tires are new what could this be…
Need help
Thanks
make sure all the lug nuts are tight by the sounds of it you didnt have this problem before replacing the tires
Thanks for the reply…I put the new tire on myself and it’s on well…I am at a loss as to what else could be the problem…any ideas? I did havr the problem before the new tire.
Thanks
Since you had the problem before the new tires, then it is probably a bearing going out.
