Lets not jump to conclusions…If reverse is the only problem, maybe you can work around that…Try putting it in “Drive” for a few seconds, THEN shifting to reverse. Maybe that will take some of the “jump” out of it. Have the motor mounts checked. A broken mount will let the engine shift position when you put it in gear…You will feel a thump or bump as the engine flops around. You can check this yourself by simply observing the engine when this problem occurs…It should not move more than 1/2 inch when you hold the brake and give it a LITTLE gas in both drive and then reverse…If a mount is broken, you will see the engine lift up alarmingly…Mounts are not very expensive to replace…
If you bought the car cheap enough, repairing the transmission might be feasible…With most Subaru’s you are looking at $2500-$3200
