How do I reset my backup camera after replacing battery?
See owners manual first.
We have the same car. I’m not aware of any need to reset the backup camera after a battery change. You might have to input a code to get the radio to work again, but the camera shouldn’t need that.
If the camera isn’t working it could be because the ECU failed to POST properly after you changed the battery. Disconnect the battery again, and leave it disconnected for at least 10 minutes, then re-connect it. That should get the ECU to boot up properly.
