Aluminum oil pan has a hairline crack but is not leaking. Dealer service says there are no aftermarket substitutes and they charge $335 for parts and $225 for labor. Is it safer to do this now or can I wait until a leak develops?
Google is your friend . I did a quick search and yes there are replacement oil pans . You should not be at a dealer for a 13 year old vehicle anyway. Call some local independent shops and you may find a less expensive solution.
Thanks for your suggestions.
---- VOLVO V70 cartalk@discoursemail.com wrote:
