So a significant amount of lead is still being pumped into our atmosphere via aircraft engine exhaust (general aviation, commercial, military, etc).
Almost all general aviation I think. Turboprops and jets don’t use it.
Some of what you write is correct. Remember that only piston aircraft use leaded avgas. Therefore, only regional airports are affected. The EPA finds increased levels of atmospheric lead up to 1 kilometer from the airport. The maximum found is up to 7 times higher than urban areas near the regional airport. Almost all of the categories you list do not use leaded avgas.
That leaves only general aviation, and some commercial(Embraer commuters) and military planes(P3 Orion, C-130).
Got it, thanks!
this is deleted
this is deleted
No, those are turboprops, they use jet fuel.
Well, to this simple-minded member, a prop is a prop is a prop.
Please enlighten me as to the differences within the propeller segment.
A turbo prop has a jet engine powering the propeller, so they use jet fuel. No pistons involved.
Thank you.
I literally did not know the differences until today.
It also took me decades to understand that only one team, in NFL football, has a quarterback on the gridiron at a time.
I’m not kidding, you’d be surprised at the sch_ I didn’t know, or never had explained to me when I was young
A turboprop has next to nothing in common with an internal combustion engine
Not completely true. It still uses the principle of suck, squeeze, bang,blow. Its just continuous vs intermittent combustion like a piston engine.
If thr 1963 chrysler turbine care would have caught on we would all be jetting around right now!
No engine block, crankshaft, connecting rods, pistons, cylinder head and valves
I say again . . .
The operating principles are very similar. Same 4 stages of combustion.
Chemical energy is converted into thermal energy on both.
Same, but different!
There is also a transmission. Very much like an automobile.
A turboprop plane has more in common with a standard internal combustion engine than we realize! A close cousin of you will.
Might be better described as turbine/prop.
Next thing you know, @Old-Days-Rick will finally admit that disc brakes are indeed superior to drums
Nothing wrong with swallowing your pride and admitting you were wrong
1940s military aircraft used drum brakes. Drum brakes helped win the war! Everything used drum brakes in the war.
Some new very high tech vehicles use drum brakes in the rear due to their superior durability.
Discs are fair Weather brakes, they like to corrode and rust up while drum brakes are cozy in their shelter.
Maybe you’ve never realized this before - BUT TECHNOLIGY CHANGES as we learn more.
Biplanes with fabric covered wings helped win WW-1. Should we return to those planes in the military?
No, we should respect them and talk about their strengths.
