a while ago i had to replace the radio/stereo (but not the speakers).
now one or both of the speakers (i’m not sure which it is. icant tell from the drivers seat) in the back right side of the car make a rattling static noise. its fairly loud and it makes the sound whether i have the music turned up or not. and it doesn’t constantly make the sound – its irregular but frequent.
changing the volume doesn’t seem to effect it, like i said it rattles whether i have the volume up or on zero. however the sound stops completely when i turn the stereo off and when the car is not moving.
when the sound started i had been listening to the music pretty loud (though certainly not as loud as i’d ever had it). i was also driving…um…over the speed limit…on a bumpy country road.
If it sounds ok when you’re stopped then I agree with @DrRocket, it just may be loose. A blown speaker would make noise whether or not the car was moving.
Most likely culprit is a blown voice coil. Given how cheaply made factory speakers are just replace both fronts with a decent aftermarket speaker and you’ll be amazed at the difference
I agree. If the problem only exists when the car is moving, it’s probably those bolts that attach the speaker to the car. Or a loose wire. Get in there and look.
