Have '94 Ranger 2.3L. Displays trouble codes 213 & 244(Spout circuit open). Changed plugs, wires, computer, and coils. Still expiriencing rough idle and check engine light. Any suggestions greatly appreciated.
Look at the bottom of this page. It shows the spout connector. make sure your’s isn’t missing. http://www.ford-trucks.com/forums/830059-where-is-the-spout-connector-on-my-93-f150-5-0-a.html
Spout connector is present. Pulled it out and checked ok for continuity. A buddy suggested it may be caused by hole in my exhaust. Possible?
Replaced ignition control module…problem solved. Thanks
