i replaced my radiator hose now my van work crank could it be because of the water that leaked onto the starter
Unlikely. Did you have to remove anything else to access the radiator hose?
no just the top hose i checked all the wires but didnt knock anything loose just changed the hose.but the side of the motor got wet like the starter and now its not cranking
i cranked it before i changed the hose and it was fine checked the oil for water or a milky look and nothing.even checked the plugs n wires they didnt get wet
think u have any ideas?
I’m thinking battery cable connections at the starter. Try removing and cleaning them and see if that helps.
Just to clarify - when you say “won’t crank…” you mean what? You turn the key and…?
