I just got a new vw bug with 1200 miles. It pulls to the right and when I had it checked at vw the tire pressure was good and it was aligned.
I was told to perhaps wait until the 5000 service and things might settle in.
I don’t think that will happen unless it’s something rubbing that will wear down in 5000 miles.
Any ideas
get a second opinion!
Should not pull unless there is an alignment problem or a tire problem.
I had the same problem on one of my cars. The tires had about 4k on them at the time. I had the car aligned and the tires rotated front to back to no effect. I switched the front tires side to side, after that the car tracked straight.
I agree that you should get a second opinion. Try rotating the tires front to back and if necessary side to side.
Good luck,
Ed B.
Or a brake dragging.
I agree, get a second opinion.
- mountainbike
