Prius Plug In charger?
The charge rate is controlled by the vehicle, it is not adjustable by the owner.
This vehicle has been designed to allow charging from an external
power source using a charging cable for exclusive use with standard
household AC outlets.
● The charging operation is designed to operate at 12A continuously
for the charge duration (up to 3 hours).
