My 2000 Hyundai Sonata GLS has a Solenoid Valve (“D” I believe) error; I am trapped in 3rd gear. I changed the input speed sensor and a bad coil pack prior to getting down to this last error. As I understand it, the error can mean that the valve is either faulty or not plugged in all the way. Can someone give me a ball park estimate on what this type of job should take, being that AAMCO and my friendly Hyundai dealer don’t want to call me back with a rough estimate? I had a good mechanic take care of the other problems before but the solenoid valve was outside of his expertise for hyundai’s.
Skypilot
2
What is the CEL code that you are getting? Please post it and someone might be able to help you.
Related topics
| Infiniti G35 Solenoid/Valve Body | 7 | 24262 | July 10, 2012 | |
| How long should it take to replace these parts? | 2 | 703 | March 28, 2018 | |
| 10-AT-010 TSB Car shifts to D3: solenoid? Aamco Discount? | 9 | 2012 | November 8, 2017 | |
| Is the solenoid valve inside the transmission part of the transmission? | 7 | 14099 | November 24, 2009 | |
| Transmission ripoff for 2000 Toyota Sienna | 1 | 693 | November 21, 2009 |
