Power Window problem - Honda Civic 2002
You go to rockauto or similar and buy a regulator/motor combo for around $40.
The motor is shot or the regulator is dry and binding. You could spend a lot of time trying to re-grease the regulator slides and moving parts and lube the cabling or spend $40 and be back to normal in short order.
