Power steering fluid leaking
I have a 1997 bonneville 3.8.Power steering fluid is leaking out of the boot on the steering rack.Is there a seal or something in there that is worn out?The inner tie rod seems to be tight.It seems to leak out when the car sits overnight. thank you
Yes, it is likely a seal. This kind of thing normally means complete rack replacement.
Here’s an alternative to replacing the rack and pinion assembly if the vehicle isn’t worth the cost of doing so. http://www.lucasoil.com/products/display_products.sd?iid=28&catid=9&loc=show&headTitle= - Lucas Power Steering Stop Leak
Lucas is not alone in offering seal conditioners that might benefit you…
