I have a 2008 Mitsubishi Lancer GTS and was wondering if there is a certain order for the make, and if so what is it?
You have a cross brake system, that is one side of the master cylinder feeds the right rear and left front, the other feeds the left rear and right front. You do both rears first, then the fronts. The order of side to side does not matter though most people do the passenger side rear first, then drivers side rear, then passenger side front and finally the drivers side front. Just be sure to start at the rear, do both of them first.
Thanks for the info.
