Passenger floor wet from leaking blower motor?
@keith the blunt end is the square piece not the pointy right?
I Drove it again today with heat and defrost on and no dripping occured. I will wait until my windshield is frozen again to replicate the problem
Yuuuuuuup.
update. Can this be the culprit? Windshield seal partly missing.
use a water hose and drown that area with water. If water enters the compartment the answer is yes.
@kurtwm1 wouldn’t it leaks l from that area when the car is off as well? Only seems to do it when heat is running
That’s correct and if it isn’t than now water comes through that part. Try cleaning the drain tube, as other suggested.
