nephew has a small leak on the cv axle seal on trans pass side case. 2012 nissan rogue. it has the 2 piece axle which uses a middle support that bolts to the bottom edge of motor. is yanking the axle a PITA? i assume you unbolt balljoint to swing out strut to get outer axle moved aside. than unbolt the center support?
Related topics
| I need help with my installed CV axle | 7 | 4009 | July 8, 2021 | |
| Broken cv joint mount? | 2 | 1343 | September 6, 2020 | |
| '06 Fusion SE Wont Move Left CV axle shot | 14 | 1046 | January 18, 2018 | |
| Can a transmission be run with a CV axel removed | 2 | 2334 | November 18, 2019 | |
| Passengers side CV axle seal continues to leak after replacing multiple times | 3 | 7339 | January 9, 2021 |
